speakers recommedation (1 Viewer)
Luke_Khuc
Hi,
A friend of mine asked me to do some research for her for a home theather speaker set (5.1). The budget is $1000. She will use it mainly for karaoke (loud but quality sound). I was going to tell her to go with the Energy Take 5 set, but the satellite pieces seem to be sooo small.
Any suggestion would be great. Thank you in advance.
MikeDuke
For that price range you may want to look at the definitive technology ProCinema speakers. You could most likely put something together for around that amount. I had some def tech speakers for a long time and they were very good.
newyork333
