speakers in built in cabnet
Discussion in 'Archived Threads 2001-2004' started by MichaelDW, Mar 9, 2002.
  1. MichaelDW
    MichaelDW Stunt Coordinator
    Dec 2, 2001
    60
    do any of you have speakers built in your entertainment centers that go down to 20hz? if so what brands, someone sugested def tech 400 but I think they have a side fireing woofer. I am building a new home and would like every thing to look like it fits tight around tv. the room is 15/20 incase that matters. as for budget for the two mains I plan on spending 1,000 to 2,000
  2. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    Michael, the DT ProTower 400 has front-firing woofers. Take a look:
    http://www.definitivetech.com/loudsp...owerimage.html
    This speaker should be fine, as well as other nonpowered speakers in the price range which have front firing drivers. If you use a nonpowered tower, you might need to feed them a lot of power to get formidable bass output. Either approach should be fine.
    Good luck!
