Speakers for my HT help
Discussion in 'Speakers' started by IvorG, May 29, 2006.
  1. IvorG
    IvorG Auditioning
    May 28, 2006
    9
    I think I am going to get the Marantz 5600 receiver and need a set of speakers to match. I want a set that will be good for both music and movies. I have about $650 to spend. It is for a living room only, 18'x16'. Any suggestions would be appreciated.
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    You might look at some of the Athena 5.1 setups. There's also the Hsu setup that could be had with a very decent subwoofer for less than your budget.
    Do you have any other requirements? Size of speakers, color, etc?
