Speakers distorting
Discussion in 'Archived Threads 2001-2004' started by Dave_Whiting, Oct 3, 2002.
  1. Dave_Whiting
    Dave_Whiting Stunt Coordinator
    Aug 17, 2002
    80
    Hi,
    I have a H/k avr 220 and some aad c 800 speakers.
    http://www.aadsound.com/Products%20P...ct%20page.html
    The manual says they are 12 ohms and they have 4 drivers like in the picture.
    When I crank it up on bass heavy music, the bass begins distorting. (about -5 on the volume control). Is this the speakers not handling the bass or the reciever clipping.
    Is there a general rule to tell the difference between the two?
    THanks
  2. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    sometimes hard to tell. If you hear a pop or slap from the drivers that is usually overdriving them.
    But - if the bass starts to loose a taught sound and starts getting sloppy that can be too little power.
    I'm sure some folks can offer a better explanation. Those speakers look like there are two passive radiators and two active mid drivers. I've owned speakers of such a design - they couldn't handle much power because there isn't much dampening in that large cabinet for two small 6.5 drivers.
    How bass heavy are we talking? Rap? R&B? Techno?
  3. Dave_Whiting
    Aug 17, 2002
    80
    Drum and bass music.
  4. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    With drum and bass being so demanding on amplifier power, I'd say the Harman is just running out of steam at the levels you desire. An outboard power amp should help. Something at least 150 watts per channel or more to make a noticable improvement. A powered sub with a filtered high level output for the speakers would be another suggestion too.
  5. Joe Wilmore
    Joe Wilmore Stunt Coordinator
    Jan 8, 2002
    130
    Not enough power in the amp. Try the HK 2.1 signature amp, it can be had for about $450.00 used.
  6. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    it's likely your receiver. those speakers (actually rated at 6ohms) look pretty hungry - having two active woofers doesn't help. [​IMG]
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    >homer voice< Must have sub for drum & bass. Mmmmm...drum & bass....>drool< [​IMG]
