donovan_chin
- Aug 6, 2001
I was wondering if I can connect 2 speakers to one channel with a minimum requirement of 8ohms. I have 2 8ohm speakers that I would like to use as rear channels. The only problem that I have is that if I connect them in parallel, the impedance will be less than 8ohms.
Can I connect them in series? That means, the red port from the first speaker to the red speaker port in the receiver.
Then I connect the black post of the first speaker to the red port of the second speaker and then I connect the black post of the second speaker to the receiver.
What is the impact of this? I know that the impedance will definitely be more than the requirement but how would it sound?
