Speaker wires?
Discussion in 'Archived Threads 2001-2004' started by Sacha_C, Jan 18, 2003.
  1. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    Well I just got the STR-DE985 receiver and SA-VE335 speakers, but there are only 3 VERY LONG speaker wires and 5 speakers, am I suposed to cut them or am I missing cables?
  2. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    Sorry, the 3 front wires were all tied togheter
  3. AaronJB
    AaronJB Second Unit
    Nov 2, 1998
    460
    Probably should be more wires included. Radio Shack or any other local electronics store sells cables.
  4. Sacha_C
    Sacha_C Second Unit
    Jan 13, 2003
    294
    All 5 were there, its just because the 3 wires for the front were tied togheter and I thought it was only 1 wire.
  5. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
    If the wires included are tiny/thin, you might try picking up some wire at Radio Shack or a hardware store (Home Depot, Lowes, etc.)--either 12 gauge or 16 gauge--and see if the larger wiring makes a difference in your system. Running individual wires may give you more flexibility with placement as well.
