Speaker Wires for Rear Speakers.....
Discussion in 'Archived Threads 2001-2004' started by Doobu Wang, Oct 22, 2001.
  1. Doobu Wang
    Doobu Wang Auditioning
    Jun 5, 2000
    9
    I purchased a Paradigm system from my local dealer. Two Mini-Monitors for the front, CC-370 for center, and ADP-170 for the rears. I am going to get bettercables speaker cable for my front and center but for the rears should I just use the 12 gauge that the local dealer threw in for free? Or should i get a higher quality speaker cable for the rears? Will I be able to tell the difference or waste of money?
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Personally, I'd use the 12 gauge that the dealer threw in for the rears. I doubt you would hear a noticeable difference right off. If you do, then order different cables later on. At this point in time you have nothing to lose by using the included cable.
