joeVee
- Jun 22, 2003
I just purchased 12 gauge speaker wire from Lowes as recommended. I now have another problem. It does not fit into the back of my reciever like the original did. Please help.
I just trimmed the wire till it fit.Uhhhh so long as the strands of wire you trimmed off dont stick out and cause a short years later.
Yes, 12 ga wire is thick. I like the Dual Banana plugs from Radio Shack (2xx-308) for behind my speakers, and the single-bananas (2xx-306) for behind the receiver. The single bananas dont stick out so far.
If you dont have binding posts that take bananas, there are pin-connectors that work well. (but I dont have the radio-shack numbers handy).
