Mark Guidry
- Dec 28, 2001
Ok right now I have my 602's and my CC6 bi-wired with two 12g wires and I am wondering what yall think. On the back of my reciever (ONKYO 676) it is a BIG mess with all the jumbo bare wire.
My questions:
1. I want to clean it up a bit so should I just run one 12g wire to the speakers like normal...is that enough?? The run is about 12-15 feet for one and about 5-6 on the other but I would like to keep the same length on both.
2. If I were to keep it biwired with the 12g I would like to use banana plugs ,but I dont know of any that take two 12g wires nicely....do yall know of any??
3. Could I drop to like two 16g wires so I cna use the banana plugs that I know of....would that be good enough???
4. If I kept it with two 12g wires could I put one end of the wire on to a banana plug and the other on a spade and then use both on one binding post??
Thanks for all the input...I will be useing the monster cable quick plugs that are the screw down type on my SVS combo so I would like to keep using them on the rest of the wireing!!
Thanks every one
Mark
My questions:
Thanks every one
Mark
