speaker wire length?
Discussion in 'Speakers' started by BrianGC, Sep 14, 2003.
  1. BrianGC
    BrianGC Stunt Coordinator
    Aug 19, 2002
    104
    Hi,
    Should the length of the speakerwire to the surround speakers be equal? I need about 35' for one side and 15' for the other. Wondering if the mismatched length would cause any problems?
    BrianGC
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
  3. KostaVan
    KostaVan Extra
    Sep 1, 2003
    17
    I've read that the wire should be similar length. But I doubt it's that important. If you can't tell....then what else matters?
  4. dale^g
    dale^g Stunt Coordinator
    Sep 4, 2003
    60
    i would say yes for the mains and the center speakers but the surrounds shouldn't matter that much.
  5. *Luke*
    *Luke* Agent
    Aug 31, 2003
    36
    I don't remember where I read it but when I was setting up my Def Tech's I read to make them the same. I run my mains and rear effects the same length to the inch....(I get bored)
  6. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    Well, I think the 2 main attributes involved are signal delay and resistance. You will not perceive the difference in the time it takes for the signal to reach each speaker based on such a short difference in cable length, and I don't believe there would be a perceivable difference in the signal strength (I assume signal strength is what resistance would impact, due to differences in the current delivered). Make sure they're both the same gauge, and a proper gauge as mentioned above. You may have a more practical situation that governs the length of cable needed for each speaker, such as the possibility that the speakers or the receiver/amp might be moved to another position.
    Doug
  7. Mat_M
    Mat_M Stunt Coordinator
    Jan 3, 2003
    225
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    There is a link to this page (though a specific area) already in my response...[​IMG]
  9. Mat_M
    Jan 3, 2003
    225
    Man did I completely miss that, John...sorry about that[​IMG]
