Speaker Wire Guage
Discussion in 'Archived Threads 2001-2004' started by James_C, Dec 28, 2001.
  1. James_C
    James_C Agent
    Aug 20, 2001
    47
    I still consider myself a newbie so bare with me...
    I have Def Tech BP8b's for my mains and I just received Def Tech BP2X surrounds for X-mas. I currently have 12 guage speaker wire running to my mains. Should I still use 12 guage for my surrounds or should I use 14??? My problem is that it will be hard to hide 12 guage under the carpet when I run it to my surrounds. Will I hear a difference??
    Thanks!!
  2. dougW
    dougW Stunt Coordinator
    Aug 14, 2000
    241
    Well, technically, since there is resistance (loss) on every signal conduction, you should use the 12 gauge, since it's a longer run. Can your ears tell a difference? Maybe, maybe not. The 14 will probably work since there's not as much resistance on speaker signals as power. how long are your surround wires, 25 feet?
    Another nice solution might be flat speaker wire, color keyed.
    Lex
  3. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    Ditto for me. You can get flat 12-gauge wire from, I think, www.onecall.com.
  4. James_C
    James_C Agent
    Aug 20, 2001
    47
    The speaker wire will be roughly 45 feet (routing it around the room)for the rear left and about 30 feet for the rear right.
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Several high-end speaker sites (not trying to sell wire) recommend:
    0-10 feet: 16 ga
    10-20 feet: 14 ga
    20+ feet: 12 ga
    So the longer runs want THICKER wire, not thinner.
    But to get real-world: your rear speakers are still considered "effect" speakers for most movies. They do not carry dialog or critical sounds, and the sounds they do carry are often duplicated by the fronts. This means you can get away with 14 ga and not notice any difference.
    Hope this helps.
