speaker wire gauge
Discussion in 'Archived Threads 2001-2004' started by Matt Weldy, Oct 19, 2002.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    Is 14 gauge ok for surround sounds?
  2. keir
    keir Stunt Coordinator
    Jan 16, 2002
    182
    yep.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    14 is good, I concur.
  4. Matt Weldy
    Feb 4, 2002
    335
    I forgot to mention that it is a 50 foot run
  5. Bill Street
    Bill Street Stunt Coordinator
    Jul 18, 2002
    135
    14 should still get you for a 50' foot run, though you might want to go down to 12 just to be sure.
    Bill S.
  6. Je-P
    Je-P Stunt Coordinator
    Oct 18, 2002
    90
    What gauge should fronts be?
  7. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    12 is fine for the fronts. You can go thicker guage if you are doing really high powered stuff but in most cases, 12 is more than fine.
  8. Je-P
    Oct 18, 2002
    90
  9. DerekM
    DerekM Agent
    Oct 3, 1999
    35
    That speaker wire is definately adequate. It looks good, too. Personally, I just use the 12 guage stuff from Home Depot. It's cheap, and it works (equally as) well. Just my opinion, of course. I think that quite a few others here share my feelings as well.
  10. BradJudy
    BradJudy Stunt Coordinator
    Sep 25, 2002
    211
    I just bought some Canare 4S8 cable for speakers. It is 2 pairs of 16 gauge cable (combine for one 13 gauge pair or keep separate for bi-wiring/amping) and is only $0.41/foot at Markertek which puts it on par with basic 12 gauge stuff price wise, but with the flexibility of having two pairs.
    Of course, that stuff on eBay is really cheap if you actually want 500 feet. If you're only going to use 100 feet, you might as well get something else.
  11. ben_fowler
    ben_fowler Extra
    Dec 1, 2001
    16
    I concur. 12 gauge is your best bet, especially for longer runs up to 50ft. And don't forget to terminate!
  12. Matt Weldy
    Feb 4, 2002
    335
    What do you mean by terminate. I just ran the wire. I did end up with 12 ga. However with flush mounted speakers the wire is so thick that the speaker dosent fit flat against the wall. Also as of right now I only have a sony cheapo reciever and I could barely get that wire hooked up to the clips for the rearr surronds (no binding posts). Denon 4802 or 4803 (if released) will be in my home at christmas time. so this wont be a problem for long.
