speaker wire for 1503???
Discussion in 'Archived Threads 2001-2004' started by Greg P, Jan 24, 2002.
  1. Greg P
    Greg P Stunt Coordinator
    Jan 7, 2001
    92
    What type of internal and external speaker wire do I need for this guy? I heard in another post that I need a low gauge or special type that can handle the 1000+ watts I will probobly feed it.
  2. I am using 12awg with no problems at all. ..just zip cord. Nothing special.
  3. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Assuming you don't want the wire to act as a resistor to either flatten a
    rising response or better match the impedance of a tube amp, then the size
    is determined by how much voltage drop you consider acceptable.
    Using the driver's Pe, Re (or total Pe, Re if multiple drivers are used),
    then with the formula:
    I = sqrt P(Pe) / R(Re)
    you can calculate ~ max current draw capability. If this number is >the
    amp's rating, then you may clip it on loud passages.
    To determine wire size required:
    Circular Mils (CM) = (2*L*I*10.8)/VD
    Where:
    L = length of wire in ft
    I = max current of circuit
    VD = voltage drop
    Some rounded off CM values based on a single solid core:
    32ga = 64
    30ga = 100
    28ga = 159
    26ga = 320
    24ga = 404
    22ga = 640
    20ga = 1024
    18ga = 1624
    16ga = 2580
    14ga = 4109
    12ga = 6529
    10ga = 10384
    8ga = 16512
    Example:
    Pe or short term peak rating = 400W
    Re = 3.4ohms
    wire run (one way) = 20ft
    VD = 1V (this is considered the max acceptable, I usually use 0.3-0.5V)
    Sqrt 400/3.4 = 10.846A
    (2 x 20 x 10.846 x 10.8)/1 = 4685.472CM, or 12ga.
    As you can see, small wire/long distances can eat up amp headroom.
    Conversely, if the amp is near/on the speaker, acceptable wire size becomes
    tiny (or Vd vanishingly low if a large gauge is used).
    At what point downsizing the wire becomes audible is of course dependent on
    the individual and his system/room.
    GM
