Jeff James
- Oct 10, 2001
Just wondering if I am cheating my system with the wire I am using for audio. Here is what I will be running:
Marantz AV9000 THX Ultra Certified Pre-amp
Marantz MM9000 THX Ultra Certified 5-channel Amplifier
Klipsch RF-3 Reference series Fronts
Klipsch RC-3 Center Channel
Klipsch Synergy Surrounds
Mitsubishi 55807 55" HD RPTV
Sony ns700p - pro scan DVD player
I'm basically running Monster cable everywhere. I bought it all at a higher end shop in town called Tweeter which a lot of you may be familiar with. I'm not sure what gauge they sold me...but it's pretty damn thick. The wires on the end are free though and that is what worries me...there are no connectors or bannana-type plugs as I've seen from browsing specs of other HT setups. Am I cheating myself by not having these type of connectors? I won't be able to change out the surround sound speaker wire since I had to run the stuff through the walls and attic. Tweeter sold me the monster cable per foot that they use themselves for running drops in custom setups....it is some heavy shielded stuff but the wires inside aren't super thick.
I'm going to get some high quality interconnects for the pre-amp/amp setup (prolly spend 30-35 per pair and have them custom built by a member of our board here).
So, let me know what your opinion on speaker wire is...I'm sure you guys have some
Thanks in advance,
Jeff
Thanks in advance,
Jeff
