Spottedfeather
- Sep 29, 2006
- Matt
I'm setting up a raspberry pi system soon...I hope. I have a question. I would be getting an amp to run the speakers. The amp I'm looking at has a 3.5m input plug. Which I would use to run a wire from the LCD controller board on the arcade 1up I'd be using. The amp uses bare speaker wire outputs. Because I want to be able to balance the sound from left to right so it sounds balanced (I have a weird hearing thing where I hear more out of my right ear than my left ear), I found a device that will allow me to raise or lower the volume of the right, or left, speaker.
That device uses 3.5mm for the input and outputs. I have found an adapter that has a 3.5m plug on one end and bare speaker wires on the other end. Will this adapter work either way ? Using either the bare wire or 3.5m plug for output ?
