Brandon B
- Mar 23, 2001
I am building a DIY 7.1 surround system this summer, and am unclear on what determines a speaker's power handling capability.
I am building 7 MTM's and am adding bass module for the LCR mains. The tweeter I am using carries a rating of 100W, and the midbasses as a pair carry the same. On the desing specs at Orca Design (the Aria 5A) it gives the speaker overall a rating of 100 watts.
So my question is, the 100W rating the tweeter's mfr states, is that presumed to mean when it carries the portion of the spectrum it was designed for, the passed portion of the full spectrum 100W/channel is all it should handle? Or does it mean the tweeter alone can carry 100W just in its passband? Ditto for the mids. Seems not to me as tweeters carrying a full 100W should explode skulls for a mile.
I ask because, as I am adding a bass module for the fronts, with a driver that alone can carry another couple hundred watts, this will unload the mids from the severely power taxing lower bass portion of the spectrum, and it seems to me should increase the overall power handling capabilities of the drivers as a system. I need to know this to spec amps (I am building these as an active system).
Also, any thoughts on Marchand's power amps as compared to something like an Odyssey Stratos would be appreciated.
BB
BB
