Speaker Volume & Position
Discussion in 'Archived Threads 2001-2004' started by Damian Giddins, Sep 27, 2002.
  1. Damian Giddins
    Damian Giddins Auditioning
    Aug 10, 2002
    4
    Hello all, from a newbie.
    I have only had my home cinema system for a month or so and am only just getting the speakers setup properly (had minor problem of removing sister from her room before creating home cinema in it ;-)
    As i have a 6.1 system i have the two fronts and centre in the 'usual' positions pointing at me, the two surrounds about 1.2m to the left and right of me and slightly above ear level (about 30cm) and the surround backs are just below ear level directly behind.
    I got the 'set the surrounds above ear level' etc from the Dolby website, but they don't mention anything for EX/ES's extra speakers.
    Does this positioning sound good?
    Should they all be set to give the same volume level during the 'white noise' setup feature ( I have read the other posts about setting the sub to a higher level than the others.
    Any ideas/help greatly appreciated.
    Damian
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I think its generally better to continue the upward climb and put the rear back above ear level, at least as high as the surround L/R, if not a tad higher. You'll notice this is the way it's done in theaters, and although this may be because the floor slopes up towards the back, it's still generally recommended to place the surround above ear level, and the rear the same way or perhaps higher.
  3. Damian Giddins
    Aug 10, 2002
    4
    Cheers, I'll give that a try
    Skiddins
  4. Dave Nibeck
    Dave Nibeck Stunt Coordinator
    Feb 23, 2000
    152
    As for the sound level, it should be the same across the back.
