Speaker Switching
Discussion in 'Beginners, General Questions' started by TonySRS, Mar 4, 2004.
  1. TonySRS
    TonySRS Auditioning
    Mar 3, 2004
    6
    I have a quick question. I am buying an HK AVR 225 and there is no option for A/B speaker switching. What exactly does that do. Also there is no component video connections, is that something I can do without??
  2. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    If you don't need to switch component connections with your receiver, you don't need it. In other words, if your TV has enough component inputs to handle all of the equipment you have, and if you're not terribly inconvenienced by having to switch inputs on both your TV and receiver, then it's not an issue.
    A/B speaker switching allows you to have two sets of speakers connected to your receiver, and you can usually only play one set of speakers at a time. I suppose this would be useful for A/B comparisons (hence the name) or maybe you'd use it if you had seperate sets of speakers for music and home theater.
  3. TonySRS
    TonySRS Auditioning
    Mar 3, 2004
    6
    Good deal, thanks for the quick response I appreciate it!!
