kyutaek
- Jan 22, 2004
I have Sony 36' HS510 HD ready Tube TV and Onkyo SR701. I want try to set up a speaker system for
my living room (16 x 16). I am newbie to home theater system. The usage would probably be half audio/half DVD (video). My budget is little tight (about $500). I am wondering if the tight budget could have the receiver fully performed. I might have two options: to buy a home theater system package or buy them separately. For the former, I might save the money by sacrifising the performance. And, for the latter, vice versa. Is it true?
What might be a good choice if I buy a speaker package?
If it would be better to buy them separately, how can I allocate my tight budget? It would be great if you recommend each part of the system (front, center, woofer, satelite). I don't have any particular brand/model in mind. I might upgrade the indiviual part as my experience on home theater getting settled. So I might need popular brand/part which I can sell them easily with a good resale value.
Another (technical) question: Is there any difference between buying a full tower speaker and buying a bookshelf speaker in building a home theater system. Tower speakers seem to be good for decoration as well, but difficult to move/set up at smaller place (also seems to be more expensive). I think subwoofer would be the same case. The bigger (12') one seems to be better, but hard to carry/move.
I appreciate your valuable input to build my first home theater system.
