Speaker Stands
Discussion in 'Archived Threads 2001-2004' started by Tim Kline, Jun 6, 2001.
  1. Tim Kline
    Tim Kline Stunt Coordinator
    Oct 1, 2000
    245
    Anyone have any recipes for Speaker Stands? I need something for my rear speakers (they're small bookshelf speakers) that will put them at the 2-3' above the ear position. Regular stands you buy just aren't high enough.. I'm guessing maybe they have to be like 4-5 feet high. Because of the way my room, and my speakers, is shaped, it makes it too hard to use wall mounts, so what I really need are really tall stands, and I don't want to spend a lot on them.
    I thought of maybe using PVC pipes but I don't know if they're the look I want, even if I paint em. The speakers have a very wide screw hole on the bottom that I'd like to use to mount the speakers to the stand with
    Anyone have any ideas?
    Tim Kline
    HT Newbie Extraordinaire!
    [email protected]
    www.timkline.com
    My DVD List
    My Home Theatre
  2. Steve Peterson
    Steve Peterson Stunt Coordinator
    Jan 3, 1999
    63
  3. Han
    Han Second Unit
    Jan 13, 2001
    262
    I assume a solidly built all-metal stand is the way to go, but what about other methods? Especially if cutting is involved, I'm not going to be cutting metal for the base and the top.
    How are the vibration levels on:
    -Metal posts plus wood bottom and top
    -All wood
    -Plastic pvc tubes plus wood bottom and top
    I'm looking at about 36 inches high for the posts.
    Would filling the PVC tubes with sand or shots bring the vibration level down comparable to metal?
    Also, glue, screws, or both?
