Speaker Stands Recommendations?
Discussion in 'Archived Threads 2001-2004' started by Josh O, Nov 7, 2001.
  1. Josh O
    Josh O Agent
    Aug 25, 2000
    27
    Can anyone recommend a set of suitable speaker stands to hold the 10" x 10" 22lb JBL S26?
    I need a height of 48 - 60".
    My concern is that to find stands that will hold these speakers, I'll have to spend quite a bit. Since these are for a temporary situation, I'd rather not spend a lot.
    Thanks for any info!
    j
  2. Brian Mansure
    Brian Mansure Second Unit
    Mar 15, 2000
    460
    Josh,
    There are a few pre-manufactured stands that you could get but for the height you want the stands will probably cost a little bit more then what you want to spend.
    I suggest building your own. See the link below for a great design for a flexy speaker stand. http://www.extremezone.com/~stpeters/Flexyss.html
    Hope this helps.
    Brian
    BAM
