JeremyR
Alright guys.. with your help I have happily moved into some Paradigm speakers and out of my HTIB speakers. Now, I have two Titan's as my mains, two Atoms as surrounds, and a cc-170 center. My atoms are sitting on shelves and are around 4 inches or so from teh wall which seems to be adequate enough considering they're ported out of the back. My CC-170 is sitting inside, well, a cabinet more than anything that's in my entertainment center. However, the front of it I have pretty much flush with the front of the entertainment center, and there's about 3 inches open space above and an inch open space on each side. There is also no back on the entertainment center, so from my vantage point it doesn't seem that the sound from the center has been compromised because there is nothing for the sound really to reflect off of (no back). However, one concern with the center I have, is that it sits about a foot and a half higher than ear level, and for some reason Paradigm found it necessary to angle the drivers up (???) which concerns me. Would putting something underneath on the backside to try and lift the back be a problem? I can't figure out what it would be though because I certainly dont' want it to slide, and I don't want it to be something that will affect the sound. And finally my Titan's are currently residing on each side of my entertainment center sitting on two huge 25 year old floor standing Mitsubishi speakers. I don't have any feet on them to minimize the affect that the speaker has on what it's sitting on which I know I need to do if I keep them sitting there. What benefit exactly would I get from replacing these with speaker stands? I'm concerned about stability of the stands, as my stairs coming down are right there next to where the speaker stand will be, and we'll soon have children, I don't want anything that can be knocked over. But I also don't want to compromise the sound, so will the sound improve with stands? I've also heard that having other speakers in the room compromise the sound. Sorry for the long-winded message. Thanks in advance for any help...
