Todd*Sa
Grip
- Feb 23, 2004
Yes this is a HTiB system. I will preface this post with this: This is the best system my budget allows, I already know this is not the preferred HT setup.
That being said, can anyone recommend a set of speaker stands for the front and a set of wall mounts for my rear speakers? I will need silver stands and mounts. I would like for the rear speakers to be able to swivel at least horizontally. Here are the dimensions and weight for the speakers:
Front-9.1"(D),6.2"(W),15.25"(H) 7.5lbs.
rear-4.9"(D),6.9"(W),9.25"(H) 3.5lbs.
As you can see I will not need anything heavy duty but I do want something visually appealing (especially the stands!).
I would like to spend less than $150. Thanks for your suggestions, you guys here really know what you are talking about!
