Speaker spikes?
chris_sharpe
Reaction score
Points
I have recently been adjusting my speaker set up, just went bi-wire last week, and I remembered my main speakers came with spikes. What are these for and will they do anything to help my overall sound quality?
Chris(rookie home theater nut)
Brett DiMichele
Producer
Reaction score
Points
Brett Andrew DiMichele
Chris,
Spikes basicly pierce the carpet and touch the substrate
(Plywood) and this ties the speaker to the floor so that
you get better bass output. Also spikes are useful for
adjusting the angle of your mains. I have my AR9's angled
upwards about 30 degrees so that the mid's and highs shoot
to ear level at the "sweet spot"
chris_sharpe
Reaction score
Points
Thanks Brett that helps. I think I will put the spikes in tommorow, but I live in an apartment will the spikes cause more downward noise?
And another question what gives better sound having the bass out go through the sub-woofer only or through the sub and the mains(my amp has the option for both)?
Thanks Again,
Chris
J
John Morris
Guest
Chris: sounds like you need to calibrate your system. Refer to the many threads on that topic for help. In the meantime, try the spikes and see what your neighbor says. When I lived in an apt., I decided to invite my neighbors to my sat night movie and soon it was an occasion and not a police action.
BTW... always slide when in doubt!!!
Montelereplay
