Speaker Setup (1 Viewer)
EdReed
I'm lookig for suggestions on speaker set up for HT.
Equipment:
Mains=Infinity IL 50 w/10" powered subs
Surround=Cambridge soundworks
Centre=same as above
Sub=8" powered camb soundworks
Should I use the subs in mains for lfe
should I also use 8" sub for lfe
Should I connect a sub to the centre channel
Eddie
ColinM
Skip the seperate sub...
Get a center with the same tweeter as the mains...
Set all speakers to small and let the LFE run through the subs, if the Infinity's are flexible enough....
If I had more time I'd embellish
Good Luck
rekhasharmatdiu
