Speaker Setup help needed!
Discussion in 'Archived Threads 2001-2004' started by Joel Verinder, Feb 14, 2003.
  1. Joel Verinder
    Joel Verinder Auditioning
    Dec 19, 2002
    13
    Let me start off by describing my system.
    Harman Kardon AVR 320
    speakers:
    Front - 2 Klipsch RCW 5s
    Center - Klipsch RC3 II
    Rears - 2 Klipsch RCW 3s
    Sub - Infinity IL20
    Outdoor - JBL NAW2II ?
    When I hooked up my ourdoor speakers, the volume was softer than the main listening room. I used a 14 gauge wire to connect them with a Monster 4 port switch box. Can someone tell me why the volume is softer outside? It is really annoying when I have to turn the inside speakers up really loud to get the outside speakers to sound good.
    Thanks!
    Joel
  2. Leo
    Leo Second Unit
    Apr 4, 1999
    292
    How far outside is the run of wire to the speakers? How are the outside speakers and the inside speakers split? Do you run both sets at the same time? Is there another amp driving the outside speakers or is it sharing power while driving the inside speakers?
  3. Joel Verinder
    Dec 19, 2002
    13
    I am running 25 feet of 14 gage monster wire to the outdoor speakers. They are running through a 4 port monster speaker selector. So I can run both at the same time or independently. I am currently using one amp to power the speakers..
    Hope this helps..
  4. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    klipsch speakers are much more sensative than those jbls, which is probably one reason why the jbls sound softer. plus you probably dont get any room reflections outside to make them sound louder.
  5. Jose G
    Jose G Supporting Actor
    Aug 18, 2002
    568
    David took the words out of my mouth almost to the letter. So I'll add: Can you use the receiver to re-set the speaker output levels for a better match?
  6. Joel Verinder
    Dec 19, 2002
    13
    I don't think I can do that with my current setup. When using a speaker selector, you lose some of your flexibility. This is nice information for the future, live and learn I guess. I'll try installing my 2nd used receiver using the multiroom features..
