Keiwana
- Jun 20, 2003
I was reading an article,Setting Up a Hometheater on Liquidtheater.com. The author states that when setting speaker size, you should always set the all of the speakers to small unless you have 200 watt seperates. His reasoning was that most receivers are not equiped with the wattage to handle full range floor standing speakers in multichannel setting. As a result the all of bass frequency should be sent to the sub to allow less strain on the receiver, therefore allowing to reciever to give a better sound.
Is this true, or should I set my speaker setting based on their size?
