Speaker Setting - SML or Large/Two Sub Setup
Discussion in 'Archived Threads 2001-2004' started by Adrian Ramirez, Aug 12, 2001.
  1. Adrian Ramirez
    Adrian Ramirez Auditioning
    Nov 27, 2000
    9
    I have the Yamaha RXV-795a with Klipsch Mains, Center, & Dipole Surrounds. To best optimize my HT setup, how should I configure the speaker set up on the receiver to Small or Large?
    Also, I have a JBL 12" sub and would like to purchase an additional one. How do I set up this configuration? Where should I place dual subs for optimal bass? Finally, do I use a Y-adapter to split the LFE signal from the sub output from the receiver to two separate 12" subs or is there a more effective and efficient method?
    Please help!!
  2. Brian Fellmeth
    Jul 30, 2000
    789
    Most people are better off with all speakers set to small. Let the sub handle all the low stuff- thats what its there for. Your Klipsch and the Yamaha will be unburdoned of low frequency which saps their energy.
    For placement of 2 subs, believe it or not, optimal is side by side (or one atop the other) in a corner. Be sure the phase settings on the subs (there may or may not be a phase switch or knob) are matched. Just split the sub out with a RCA Y adaptor.
