Martin Fontaine
- Aug 15, 2001
I know that a speaker's sensitivity rating means the SPL that is readable at 1 Meter when there is 1 Watt of power. And that whenever the volume level (dBs on the receiver's volume dial) changes by 10 dBs, the wattage is multiplied/divided by 10.
My Paradigm Titans are rated for 90 dB @ 1w/1m. And my Kenwood VR-509 can do 100 Watts per channel (Ok, so maybe with all channels driven, it can't get that high but that's besides the point here)
So in theory, if I set the volume level on the receiver at -20dB, I should be outputting 1 watts (Assuming the signal is a peak)
Calibrating with S&V (Which is basically Avia jr. so the 85db=Ref should be valid right?) Ref level is -18 for AC3 and -22 for DTS (I usually listen to my movies at 10 under ref so -28 or -32)
If at reference (-18) I'm just over 1 watts (Probably just a little under 2 watts) then my speakers should spit 92dBs since doubling the wattage adds 3 dBs of SPL. Then why would I get 105 dB at that volume level then?
The formula just doesn't seem right here. I'm sitting maybe a little over 1m from the speakers but still, this doesn't make sense.
And when I put MP3s from the PC (SPDIF output) anything above -40 is too loud (Probably near ref) so there again, the formula makes no sense.
Anyone know why?
Anyone know why?
