Dan Kaplan
- Aug 17, 2002
Does anyone have any recommendations for an inexpensive speaker selector that can handle 2-4 sets of speakers? I was looking at the Niles SPS-4 and SPS-6, but the drawback to them is they appear to only accept bare wire or pins (no banana plugs, spades, or 12 guage or thicker wire), which doesn't work overly well with my setup.
I don't need volume control, massive power handling, remote capability, or the ability to play multiple speaker sets at once or feed multiple amps into one set of speakers... Simple and reliable will do. Something common enough to have a decent chance of being found used would be preferable. I like the low profile of the SPS-4/6; better than Niles' old boxy looking units. That's a minor issue, though.
So, anything come to mind that fits that bill?
Dan
Dan
