Joe_Papeo
- Jan 1, 2001
I need to purchase a speaker selector ASAP.
Here is what I want to do....
Outdoor System
2 pairs of Mirage Outdoor speakers
-1 pair facing the pool
-1 pair facing the patio
1 pair of Polk speakers inside the garage
1 Denon 2 channel amp inside the garage.
I would like each pair of Mirage on a volume control
-can I use one volume control for 2 pairs?
I do not want to put the Polks on a seperate VC. I would just use the main control inside the garage.
WHat do I need?
More specifically....
Do I need a speaker selector that has a volume control on it?
I am assuming I need a speaker selector with impedance matching.
The volume control is impedance matching, or at least the Nile ones are. Do I need impedence matching on the VC if only one pair is wired to it?
If I dont have VC on the speaker selector does every pair of speakers have to have a seperate VC?
Can I use a SS with no VC and use VCs for the 2 pairs outdoors but not the one pair indoors?
Does any of this make sense?
Outdoor System
WHat do I need?
