Speaker Selection Help
Discussion in 'Speakers & Subwoofers' started by Giob, Jan 17, 2005.
  1. Giob
    Giob Extra
    Feb 8, 2004
    21
    Hi, I'm just starting to buy components for my home theater. I am choosing between 2 brands of loudspeakers that's right for my budget:
    Wharfedale:
    Center 120 watts, 6ohms $81
    Front/surround 100watts, 6ohms $100/pair
    Subwoofer 150w $160
    Gale:
    Center: 100watts, 4-8ohms, $75
    Front: 100watts, 4-8ohms, $120/pair
    Surround (dipole): 90watts, 4-8ohms, $94
    Subwoofer: 100watts, 4-8ohms, $180
    What would you recommend between the two?
    Thanks for the help.
  2. Giob
    Giob Extra
    Feb 8, 2004
    21
    no takers? thanks
  3. MikeLi
    MikeLi Supporting Actor
    May 6, 2003
    945
    That might be ok for a very small office or room space. Hard to recommend anything without knowing what your space is and what your trying to accomplish. I am not familiar with either brand but if you could up your budget just a few hundred dollars you could easily get into a much better product.
  4. Giob
    Giob Extra
    Feb 8, 2004
    21
    Mike, if i had a few hundred dollars, which brands would you recommend?
  5. MikeLi
    May 6, 2003
    945
    Go to av123.com and look at some of their specials. Once you buy from them you will never buy speakers anywhere else. Plus they can give you a package deal with a receiver and such. Better yet just call them up and say I have this much to spend... what can you do for me...? You will be surprised.
