JohnVB
- Aug 16, 2002
Hi,
I just talked to the guy who wired our house for speakers about getting speakers for our living room.
We're pretty much leaning toward getting in ceiling speakers for the rears. We'll most likely get a floor standing sub. Our options for the fronts and center have opened up since talking to this guy :-/.
Here's some of our options:
1) Get all in ceiling speakers. The installer is recommending this. He would use SpeakerCraft Speakers for this - the AIM line of speakers. We listened to a set he installed in one of the models in our subdivision. We could tell that the sound was coming from the ceiling, and it seemed this would be weird for movies. The installer said that in a bigger room like ours, we wouldn't be able to notice this. He has another system he installed in a bigger room in a different subdivision. We'll have to listen to this.
2) Have in-wall speakers for the left, center and right speakers. The installer would use the SpeakerCraft speakers again for this. This would not have the problem of the sound coming from the ceiling, but would have the disadvantage of using up wall space where we might want to hang pictures.
3) Use floor standing speakers for the left and right and an on TV center. The installer has MonitorAudio speakers (Silver 9's) that I could get for around $1000 for the pair. and a Silver Center 10 or 12 (I forget the price he quoted on this). The installer thinks the Silver 9's are mass loadable, which we would use to help stabilize them from our small children (we'd also try to arrange furniture so they wouldn't be so easy to get to). The drawback to this approach is that MonitorAudio doesn't sell in-ceiling speakers, so we'd have to go with a different manufacture for the rear speakers. Another possible drawback to this is that with the way our furniture is arranged we would likely have to have the left and right speakers sit in close to our 55" rear projection 16x9 TV. He's going to bring a set out to our house on Friday so we can listen to them. Perhaps we'll find they're tall enough so the drivers wouldn't be obscured by one of our couches, and we'd have more options for positioning.
Edited: The Silver 9's appear to be an older model of MonitorAudio speakers. The Silver 9's look to be pretty similar to the Silver S6 on their web site.
4) Use Paradigm speakers all the way around. Perhaps Monitor 9's for the left and right, and Paradigm in ceiling speakers. This would have the same possible positioning drawback as option #3.
So,
Are MonitorAudio speakers good? Would the MonitorAudio speakers sound that much better than similarly priced Paradigm speakers? Can a full in-ceiling setup sound good for HT? Would in-wall speakers be a reasonable approach? Has anyone heard SpeakerCraft speakers? If so, are they good? Is setting up the left and right speakes right next to our TV such a bad choice?
Any opinions, suggestions?
- bones
So,
- bones
