Speaker popping
Discussion in 'Beginners, General Questions' started by Philip_, Mar 31, 2005.
  1. Philip_
    Philip_ Auditioning
    Mar 30, 2005
    I have a Sony HTDDW670 home theatre system.
    Q: When I run my Advent television throught the HTS, everytime I change the channel the speakers pop? How do I rectify this?
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    I try my best to never use the Display for the audio source.
    I take this is from the normal NTSC broadcast tuner in the display?
    Can you try a hi-fi VCR for the tuner instead and feed it directly to the HTIB???
    It seems it is a nasty anommily of your particular display?
  3. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    This happen to every type of TV tunner/cable tunner unless they have the feature where it muted the volume at channel switching. I have no problem with my Proton TV set where it'll mute itself for 3 sec whenever you change a channel. But all other TV set I have all gernerate the popping sound when I switch channels.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yep, my uncle had a similar problem with his cable-box. whenever he changed channels, he'd hear this noise. drove him crazy!
