Speaker placement
Discussion in 'Archived Threads 2001-2004' started by Walter_C, Jun 13, 2002.
  1. Walter_C
    Walter_C Extra
    Jul 23, 2001
    20
    My living room is not conducive to a 5 or 6 speaker setup - due to furniture placement, etc.
    Would a 4 speaker setup be sufficient (2 front and two surround/rear)?
    I was thinking/hoping to mount all speakers in the room four corners near the ceiling.
    Thoughts on this as well as decent speakers in the $300 - $400 range?
    Walter
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    Walter,
    In order to get the maximum audio benefit from your system you'll need a center channel. It will handle the majority of the dialogue from DD 5.1 and DTS discs. Don't leave this speaker out, you'll be missing a great deal from your movies!
  3. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    If you have the 2 fronts, and 2 rears, then all that is left is a center channel and a subwofer. I am sure there is somewhere on top or below your TV that you can put the center. And the sub can go anywhere. Put it in a corner, behind the couch, even under the couch; it really doesn't matter. (OK, some of you will say that it does matter, which it can make slight differences, but it is better to have one somewhere than none at all)
