I am almost finished the construction of my HT and I wanted suggestions on placement of the front speakers and the subwoofers.
In the attached picture you can see I will be using Acoustically Transparent screen material (yes I can buy a regular screen later and put against the front wall, but I wanted to try this out first). The screen may run the width of the room, but the projected image will only be around 108" as I only have 12'1" throw distance from projector to screen.
- I put the fronts 3' from the back wall so that nothing above 80hz reflects and the rule of fifths apply (speakers should be 1/5 of room dimension from each wall). Is this ok?
- How high should the center channel be? Should the midrange line of with the midrange of the fronts
- As far as subwoofer placement should I place one in seating area and crawl around until I hear max volume, then place subwoofer #1 there, the repeat for second sub, having the first subwoofer going in its new location?
