Speaker Placement ? (Rears)
Discussion in 'Speakers' started by JeffHunter, Nov 22, 2003.
  1. JeffHunter
    JeffHunter Stunt Coordinator
    Nov 21, 2003
    66
    Hey all,
    I have a dilema on my hands. Directly behind the main seating position in my living room is a bay window which really rules out proper positioning of my rear speakers, they are of bookshelf size, but I have no where to put them [​IMG] ... or at least no *good* positioning, moving the furnature around is not an option, the lady won't have it.
    So where should I be placing my speakers ? [​IMG] I'm throwing up a jpg of my general layout but it's not exactly to scale but is as close as I could get it with minimal effort.
    to give you an idea of the scale, from the front of the entertainment unit to the front of the main couch is ~8-10 feet.
  2. JeffHunter
    Nov 21, 2003
    66
    blarg!
    wwwDOTmdb-projectDOTcom/speakerplacement.jpg
  3. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    ? [​IMG]
  4. JeffHunter
    Nov 21, 2003
    66
    you need to have a cetain number of posts before you can type in urls / image links in your posts
  5. MarkMac
    MarkMac Stunt Coordinator
    Feb 27, 2002
    112
    Jeff-I'm assuming based on your .jpg that you are talking about your surrounds. (a 5.1 setup--not 7.1) If that is the case, it looks as though placing them on the wall above your secondary seating and side table would be your best bet. While not ideal for those not in the Secondary Seating or the Lounger, it should work great for the Main Seating.
    What type of surround speakers do you have? That will help in making the decision.
  6. Mark Shannon
    Mark Shannon Screenwriter
    May 27, 2002
    1,991
    I would suggest getting floor stands for them. Unless of course theres a reason for not doing it.
  7. JeffHunter
    Nov 21, 2003
    66
    I currently have a *REALLY* cheap pair of Sony's ... in the coming months I will be upgrading to JBL rears.
    ... and yes it's for a 5.1 setup ...
    Mark,
    I was thinking of building my own out of parts, a little DIY project. Although I would like a metal construct. I'll probably use piping and some l-Joints pipes, straight pipes & *maybe* l-Joint supports (to hold the speaker)
  8. JeffHunter
    Nov 21, 2003
    66
    oh right anyhow so as far as the speaker placement is concerned, that is what I was thinking about doing ... if I do that the rears will be in front (not by much) but still in front of the main seating position. Will that still sound like rears ?
  9. JeffHunter
    Nov 21, 2003
    66
    *bump*
  10. Kevin Stewart
    Kevin Stewart Second Unit
    Oct 7, 2003
    363
    Texas
    Kevin Stewart
    Jeff,
    I have a similar set-up. I placed one bookshelf on a speaker stand that is basically in the corner by the side table (close to the corner of the room) and the other one on another stand opposite it (the other side of the bay window). I angled both speakers towards the center of the room (right at the coffee table, for example). It sounds very good from both seating positions, although obviously the sound is a little louder from the left rear when you're sitting in the secondary seats, but it's not that noticeable.
    Stew
