Frank Lee
- Nov 27, 2002
Hi
I'm fairly new to HT. I am getting some ideas to set up my rear speakers. My room is approx 28' long x 15' wide. I have the couch located right in the middle of the room (facing one of the small walls). I have a the TV up against the wall with the center speaker directly on top of it. The front left & right speakers are near the corners of the room. At the moment I have two surround speakers setting on end tables next to the couch. This set up of the surrounds seems to make it difficult to hear both surrounds if you are on the far side of the couch. I am going to get new surrounds and a rear center speaker soon. I am considering mounting them farther back in the room. The entrance to the room is in the very back so I can't mount them on the rear wall. I am thinking of mounting the rear center on the ceiling and aiming slightly down toward the listening area. The rear left and right would be mounted on the side walls up toward the ceiling and also aimed down toward the listener. All speakers will be approx the same distance (13ft) from the listening area. I think that will provide a better surround experience for everyone in the room...am I right on this one? Any suggestions are welcome!!!
Frank
Frank
