Speaker placement HT vs. Stereo (1 Viewer)
Mark Hedges
I am wondering if it is possible to have the same speaker placement be optimal for home theater and for stereo applications. It seems to me that to get the best HT sound the front mains would have to be farther apart than what would be best for stereo listening. Am I correct in this thought? What do you guys do who use the same setup for stereo and HT?
Thanks!
Mark
Phil Iturralde
The following is from Dolby Labs website ...
The left and right speakers should include an angle of from 45 to 60 degrees with the center-most viewer, as shown in Figure 6. An angle nearer to 45 degrees is preferred if you use your system mostly to watch movies, as it approximates the circumstances under which film soundtracks are mixed and monitored. A wider angle, with the left and right speakers further apart, is recommended if you use your system for music listening more often than watching movies.
Figure 6: Use the narrower angle if you mostly watch movies, and the wider angle if you mostly listen to music.
I use approx. 45-degrees, since my priority is HT.
Phil
Mark Hedges
Thanks! That is a very usefull webpage. I am not clear though if, when they say "listening to music" they mean listening in surround (DPLII etc.) mode or if they are referring to good old 2 channel stereo. Maybe I will email Dolby and ask them.
Mark
Phil Iturralde
...when they say "listening to music" they mean listening in surround (DPLII etc.) mode or if they are referring to good old 2 channel stereo.
Looking over the Figure 6: diagram, it indicates good ole' 2-channel stereo.
Logic dictates that the above Figure 6: diagram would show either 5 or 6 HT speakers if it applied to DPLII, since DPLII takes lower quality recordings in matrixed stereo (such as analogue TV broadcasts or VHS video recordings) and generates five or six channels of sound for 5.1 and 6.1 systems respectively,
Since my setup is HT priority, all other sound formats like DD-DPLII, DTS-Neo 6, etc. will be played back using my HT speaker layout.
Phil
Bob McElfresh
The goal of a lot of 2-channel music systems is to create a "image" between the 2 front speakers.
This is typically done by adjusting the angle/toe-in of the L/R speakers so the soundfield intersects IN FRONT of the primary listening position.
A simple laser pen is a nice tool to use. Just hold the pen along the outside speaker cabinent to see where the speaker is pointing. The classic music system has the 2 speakers intersecting 1-2 feet in front of the listener. Many magazine reviewers still do this when evaluating HT speakers so this alignment is not considered bad for HT.
Hint: Roll the laser pen on a flat table while watching the beam on the wall across the room. If the beam moves back and forth - the beam is aligned with the pen body. If the beam makes circles as you roll, it's not aligned and you should look for another one. Try to get the longer pen-style laser pointers instead of the small "bullet" shaped units. You can also buy a "Laser Level" at hardware stores to be sure the beam is aligned with the level.
Room to breathe
There is another speaker issue that is often forgotten with HT systems: Speakers sound better with 2-3 feet of room around them.
Instead of worrying about 40/60/80 degrees, try following the "Rule of Thirds":
Pull your L/R speaker 1/3 of the way into the room, and then place them at 1/3 and 2/3 positions along the wall.
Speakers DO radiate a lot of sound at 90 degrees to the face, and out the back. Giving space around them (and giving some toe-in) helps reduce early-reflections. And if you can get some delayed-reflections by having the speakers away from walls, you can give a room a much larger sense of space. This can create what is known as the "Hass Effect" which fools your ears into thinking the sound-source is several feet farther away than it really is.
There is also the "Circle Theory" of speaker placment:
Position your center speaker and measure the distance from your head at the listening position to the tweeter on the center speaker. Using this distance, draw an imaginary circle in front of you. Pull your L/R speakers forward and place them somewhere along this circle. The best position is one which gives the most breathing room/space around the L/R speakers. Now do the toe-in.
IMPORTANT: Use 2-channel MUSIC to test/judge each speaker placement (since that is what you are trying to optimize for). But before fireing up a DVD, make sure to use a SPL meter to level-adjust the speakers. If you dont remember to do this, you may reject a great setup just because the levels are out-of-sync.
Hope this helps.
Mark Hedges
I will use your tips to adjust the toe-in. Unfortunately due to room setup issues I cannot move the speakers in from the wall. They are currently on a tv stand giving me an angle of about 30 degrees. I am going to get some bookcases and put them in it, which will allow me to increase the angle to 45 degrees or so.
I get the impression it isn't really desireable to put speakers in a bookcase but since they have no ports (they are JBL S36II's) I figure it shouldn't hurt too much. It is my hope that any losses incured by placing them in the bookcases should be regained by increasing the separation and raising the tweeter to ear level (the tweeter is currently only 22" or so off the ground).
Mark
Phil Iturralde
Don't worry about toe-in with the JBL S36II's** and follow your plan to get some bookcases to put them in, ... increasing the angle to 45 degrees will help for both HT & Music.
I don't hear any disadvantages listening to my JBL S26's using the approx. 45-degree angle and keeping them squared-off (increases the soundstage) towards my seating areas.
From my past experience (sold audio in the early / mid '80s) toeing-in speakers may increase the high frequency limits basically pointing the tweeter center axis towards or near your sweet spot but at the expense of a compressed stereo soundstage & imaging.
**All JBL S-Series 1" Titanium Dome are integrated with the JBL TEC Award Winning LSR Studio Monitor EOS Waveguide (N-Series also) - designed to provide 50° x 100° dispersion. Objective test confirms the EOS waveguide to provide wide high frequency SPL at the usual HT speaker locations.
Phil
phyllisbernhard
