Chris_K
- Nov 2, 1999
This would be easier if I could show you a picture but I dont have access to a place where I can put it and link to it for you to see so I will try to explain - I have a rough pic if you want me to email it to you.
I have an L shaped living room-dining room combination the bottom part of the L is living room. At the bottom left corner is my TV and in front of that is the couch. To the right of the TV is the fireplace. I am trying to figure out where to put my surrounds (infinity RS3 on short sand filled stands). If I put them by the walls then they wont be equidistant from the couch. I suppose I could stick them there and tweak the volume level for each speaker. I also thought of putting them behind the couch but what should I do about the wires?
Anyone got any ideas?
