NeilO
- Aug 30, 2002
I just got my JBL NSP1 speakers and a SONY WAM40 subwoofer. I haven't hooked anything up yet. I've been trying to get things arranged in the room, which isn't an easy task. The speakers are temporarily placed at the moment. The center is on the TV about 44 inches from the floor and 20-25 inches from the wall. The right is on top of a pair of cabinets 40 inches high and 6 inches away from the wall. There is a bookshelf on the left and the 40 inch spot is in the top shelf, so I've put it there for the moment. The left and right are about 40 inches away from the center of the center speaker.
One question - would it be better to have the left and right
both on top of bookshelves 53 inches high or as I just described?
The surround speakers: I've put the left surround on the fireplace mantle 53" high at the moment. I think I might mount it to the wall offset from the mantle, if this height works. The right is on a half-wall about 42 inches high on the other side of the room. That might end up getting mounted on a pillar also 53" inches or so high, but the half-wall is where it can rest at the moment. They would be facing into where we are sitting in the room. Does this look reasonable?
The subwoofer is over to the right of the cabinets propping up the right front speaker.
Another question: I am going to be borrowing an SPL meter from a coworker. Should I get things set with that before putting the speakers in their final position? Or should they be in their final position first? Or should I iterate?
Also, is there a good link to proper use of the meter or is it "obvious"?
Thanks for any suggestions.
Neil
Neil
