speaker mounts - paradigm
Discussion in 'Speakers' started by anthony-b, Jul 11, 2004.
  1. anthony-b
    anthony-b Auditioning
    Feb 7, 2004
    4
    does anyone have any recommendations as far as speaker wall mounts for my adp-470 and cc-570 speakers? i'm just now setting up my ht and will be placing the cc above my 110" firehawk.
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    The ADPs should already have wall mounting features built in.
    I have to advise against wall mounting the center. I would personally opt for a stand mount, but that's just me.
  3. Paul Gere
    Paul Gere Second Unit
    Sep 3, 1999
    282
    Anthony,
    I Echo John's remarks.
    if possible, stand mount the center under your screen.
    Above may give you trouble with L to R panning and imaging.
    I've got my Paradigm STudio CC on a stand under my 110" Firehawk and the results are awesome.
    There are a number of good center speaker stands out there.
    Mine is a sand-filled Sound Anchor, but there are other choices.
  4. wes18
    wes18 Agent
    Oct 26, 2003
    31
    Just make sure you secure the ADP brackets securely (i.e. a stud) and use the template for placement with respect to your wiring.
    If you need to mount in a corner, like I did, then I can give some advice on how I did it.
