Speaker mounting brackets
Discussion in 'Archived Threads 2001-2004' started by Kevin Potts, Sep 4, 2001.
  1. Kevin Potts
    Kevin Potts Second Unit
    Feb 17, 2001
    328
    Well I'm getting ready to move at the end of the week and just discovered a bit of a problem today. After getting our extra couch and loveseat moved into the new pad, to my dismay I noticed that my original plan of having my rear surrounds in the place that I originally planned is not going to work. Unless I want them to get banged and broken I'm going to have to mount them on brackets from the ceiling of high on the wall. So I have two questions
    1. Do any of you know if there are mounting systems that will support 20 to 30lb speakers?
    2.Could somebody please give me some links to sites that make them or sell them.
    Thanks in advance guys.
    [​IMG]"See the world on the wings of rock and roll"
  2. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,239
    Best Buy sells these for different size speakers. There is one that will hold 25lbs. I used to use them. They look great and are very sturdy. I am sure some can give you links to online vendors that sell similar mounts as well. They are $69.99 at Best Buy.
    This will probably do the trick. Speakers tend to feel heavier than they are.
    http://www.bestbuy.com/Detail.asp?m=111&cat=173&scat=&e=11001072
  3. Ellen
    Ellen Stunt Coordinator
    Jan 8, 2000
    142
    Ellen
  4. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    Do a search for b-tech on the web.
  5. RodC
    RodC Stunt Coordinator
    Feb 8, 2001
    60
  6. Kevin Potts
    Feb 17, 2001
    328
    Thanks for the quick replies folks. I think I'll probably end up going with the Omnimounts but I'm still looking. Any other suggestions?
