Speaker matching question - Frequency Response.
Discussion in 'Archived Threads 2001-2004' started by Robert Derouen, Mar 9, 2002.
  1. Robert Derouen
    May 26, 2000
    38
    I'm still a newbie as far as technical aspects of speakers go. I am trying to find the best surrounds to match some Klipsch KSF-10.5's as mains and a Klipsch KSP-C6 as center. I am told that it is best to match your surrounds specs as close as possible to the rest of your speakers.
    In comparing the specs of the center and mains, everything looks basically the same except in Frequency Response;
    Mains Frequency Response: 36Hz-20kHz+3dB
    Center Frequency Response: 63Hz-20kHz+3dB
    They quit making these models a few years ago so I will probably be buying a non-Klipsch surround with similiar specs or building my own. Should I match the surrounds with the 63Hz, the 36Hz, or does it matter?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Frequency response would not be the deciding factor. What you want is speakers that sound similar, and this has less to do wtih their frequency response than it does with the type and material of the drivers, crossover and cabinet design. If you stick with Klipsch, with at least a similar tweeter, you should have no problems.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Robert,
    Maybe you could find the rest of your speaker set one-bay or something.
    Wayne A. Pflughaupt
