Speaker Impedence
Discussion in 'Archived Threads 2001-2004' started by Shanil, Dec 7, 2002.
  1. Shanil
    Shanil Extra
    Dec 6, 2002
    19
    HI there. I have a Denon 1803, and Jamo speakers. The speaker impedence rated on the reciever is 6 to 16 ohms.
    My front and surround speakers are rated at 4 ohms, and the center is 8 ohms. Is it safe to use these speakers or
    will I damage my receiver?
    Thanx
  2. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
    Shanil,
    You should be OK if you give the amp plenty of breathing room and don't play at loud volumes for extended periods. I don't think you'll cause damage. Most likely your amp will overheat and the protection circuit will shut it down.
    -Robb
