Kevin Reckelhoff
- Aug 16, 2001
It's a low-budget center channel speaker in a 3-speaker setup. The center channel seems to be "losing connection" with the source for some reason. Is this likely a problem with the connection (spring clips with 18gauge speaker wire), or with the speaker itself?
Simply re-inserting the speaker wires doesn't seem to be working.
any help appreciated.
