Speaker & Electrical Wire
Discussion in 'Archived Threads 2001-2004' started by RucoreyZ, Feb 20, 2002.
  1. RucoreyZ
    RucoreyZ Auditioning
    Feb 15, 2002
    7
    Before my first post, thanks for all your input on this forum. My lurking has giving my tons of useful advice in building my HT!
    I'm finishing my basement and am taking my time in designing my perfect HT. All of my electronics are built into the walls and my question (finally) is this. What is the minimum distance, if any, between speaker wires and electrical so that there is no interference? I'm using Monster MP and 12ga electrical.
  2. Dave Bertrand
    Dave Bertrand Auditioning
    Nov 25, 2001
    13
    Welcome to the forum! The minimum recommended distance is 16 inches. If the speaker wire and electrical cable must come closer, try to make sure they cross at a 90 degree angle. What you really want to avoid is close parallel runs. If your studs are on 16" centers, make sure you don't put vertical runs of speaker wire and electrical cable in the same stud cavity. Good luck!
  3. Ron Shaw
    Ron Shaw Stunt Coordinator
    Dec 4, 2001
    142
    Also, you can use a trick used by distributed sound engineers of twisting your speaker wire, if it runs close to AC. This causes any AC induced interferance to be common mode.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    56
    9,110
    Katy, TX
    Wayne
  5. Ron Shaw
    Dec 4, 2001
    142
    No need to separate the two strands of zip cord. They twist just fine as they are. A trick we always use is to stick one end into the chuck of an electric drill and twist them that way.
  6. RucoreyZ
    Feb 15, 2002
    7
    Thanks for the advice, I don't want to criple the entire HT with poor wiring!
