Speaker Distances
Discussion in 'Speakers' started by Chris Huber, Apr 29, 2005.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
    Eventhough I have set the distances on the reciever, do I still need to set them on the DVD player aswell? Or does it the reciever just cancel out those settings?
  2. Mark Dill
    Mark Dill Stunt Coordinator
    Jan 20, 2005
    148
    If you set them both, then you will have double the delay. I would just use the ones on the receiver.
  3. Chris Huber
    Jan 2, 2003
    416
    So, just leave tehm default set to 10ft in distance?
  4. Mark Dill
    Jan 20, 2005
    148
    Yes, as long as the distance to all speakers is the same, your DVD player will not introduce any delay.
  5. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    Usually the DVD player only affects the speaker settings for the 5.1 analog outputs. If you are using a digital (optical or coax) connection, the DVD player passes the raw digital data, with the possible exception of turning the DD "night mode" byte on/off.
  6. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,357
    293
    Cees Alons
    Chris,
    If you're using the receiver to decode the DD or DTS signal, you're not using the decoder logic of the DVD-player. The sound signal goes undecoded to the receiver, so no distances are changed yet before it is decoded there. Only the setting on your receiver matters.
    Hope this helps.
    Cees
  7. Cees Alons
    Jul 31, 1997
    19,357
    293
    Cees Alons
    Ah! Jeff just said the same!
    Sorry, Jeff (and Chris), parallel input. [​IMG]
    Cees
  8. Chris Huber
    Jan 2, 2003
    416
    Thanks guys...
