Speaker distance settings
Discussion in 'Archived Threads 2001-2004' started by Mark Butler, Jan 21, 2002.
  1. Mark Butler
    Mark Butler Stunt Coordinator
    Aug 7, 2001
    70
    I was wondering what difference setting the speaker distances on the amp makes? Does the speaker get louder if you set the distance further way and does it get quieter if you set the distance closer. Any help is appreciated.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    It has to do with phase and how the timing of the sounds arrive at your ear, as your speakers will often not all be the same distance from your listening position.
    I doubt it has anything to do with volume, as that is typically a separate setting.
