Speaker designs suitable for all channels
Discussion in 'Home Theater Projects' started by AaronR, Feb 5, 2004.
  1. AaronR
    AaronR Auditioning
    Feb 4, 2004
    I’m looking for a little advice. I just finished building a Sub/end table (Adire’s Tempest – mid Q set up) and am really happy. It inspired me to build the rest of my HT speakers. I’ve looked at designs at Speakerbuilder.net and murphyblaster.com. The MBOW1’s get rave reviews but are these appropriate for use as Left, right and surround speakers? Or even as a center channel? I’d like to find a design suitable for all four speakers and a matched center channel.
    The other thing is I have just finished remodeling our living room which has built in shelves surrounding our new 65in Mitsubishi. I’d like to find speakers that I can also place in the shelves around my TV so rear ported speakers (like the MBOW’s) might be a problem.
    Thanks for any help.
    Aaron.
  2. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    You'll get several suggestions in reply to your question, but I suggest you first set a budget and then re-ask your question.
    Also, there's usually enough room on the speaker baffle to move a port location from rear to front.
    BTW, I'm not of the camp that believes that the surronds have to be the same speaker as your LCR's.
  3. Alex_V
    Alex_V Auditioning
    Feb 5, 2004
    2
    From all I've read, the Adire 281's are great all the way around, although I'd probably go with the 81's as rear surrounds simply for cost. You would probably get more suggestions if you gave an estimate of what you're looking to spend.
  4. David_P
    David_P Stunt Coordinator
    Dec 12, 2003
    149
    check out the Spires at Creative Sounds and RAW Acoustics web sites... they're only good down to 100hz or so, but they're fully shielded, quite efficient, and have fabulous imagining. I heard a set including center channel at the Surrey DIY2003 event back and November at Al's (RAW acosutics) place and they sounded very good to me.
    Very economical if you can do nice cabinets, and the cabinets shown on both sites are made by Al (RAW) and look even better in real life.
    David
  5. Luitz
    Luitz Stunt Coordinator
    Jan 4, 2004
    139
  6. Steve Elias
    Steve Elias Stunt Coordinator
    Jan 1, 2002
    126
  7. Luitz
    Jan 4, 2004
    139
  8. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    Considering the main topic is home theater I agree. Where it does benefit is with the latest surround DVD-As and SACDs. For example, Telarc's 1812 Overture DVD-A that contains live cannons arranged in a circle, recorded from the middle of the circle and then fired so the cannonfire changes from front, to center, to back, to the side, etc..Have the same speakers all around makes for much better playback in this situation.
